Gears & Axles - S60 sawpp
GYTR-YAMI
07-10-2012, 10:34 AM
Dont have the reaer end quite yet but should be coming soon! I figured id post up some of my progress thurs far.
dennsterTA
07-10-2012, 12:19 PM
Looking good. I'm thinking of doing the S60 too so any pics along the way would be great!
02chickenhawk
07-11-2012, 08:57 AM
Sweet. You are going to love the S60.
BrianSF-GA
07-11-2012, 11:43 AM
Looking great ... definitely an important mod no matter what rear one goes with ... S60, 12-bolt or 9" .... !
Here are a few photos I posted of my install last year ....
My S60 delivered & unpacked.
-Strange Engineering PRSF10
-35-spline Pro Race axles
-axles drilled & tapped for 1/2”x4.5”, 4.75” & 5/8”x4.75” studs
-35-spline spool
-1350 series pinion yoke
-4.10 ring and pinion
-2”x1/2” wheel studs
-BMR adjustable (3-hole) lower control arm brackets (welded)
-Strange Engineering 3" Chrome-moly driveshaft with transmission yoke and 1350 U-joints
Thank you Carl at Central Racing Parts (CRP).
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3329-2.jpg
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3503-1.jpg
Spohn drag sway bar, lower control arms, chassis mounted torque arm & panhard bar rod. All rod-ends.
Thank you Steve at Hawks Camaro for price matching a killer deal & quick shipping.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3454-1.jpg
Cleaned & etched with POR-15’s Marine-Clean & Metal-Ready.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3346-1.jpg
Coated with POR-15.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3359-1.jpg
Out with the old 10-bolt.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3467-1.jpg
In with the new S60.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3479-1.jpg
S60 completed.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3516-1.jpg
Sphon drag sway bar & panhard bar rod.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3521-1.jpg
Spohn chassis mounted torque arm & lower control arms.
http://i858.photobucket.com/albums/ab147/annetteandbrian/Camaro%20SS/Miscellaneous%20Posts/Dsc_3511-1.jpg
Notice the drag sway bar has offsets to clear the shocks like the BMR’s and UMI’s. I was planning on the “straight” style Spohn drag bar which others have been able to fit to the “stock” sway bar mounts. With this “new” style, I ended up having to cut off the “stock” sway bar mounts and used the Spohn mounts. There is plenty of clearance from the shocks though. If you plan to run a drag sway bar, remember to order a rear without the “stock” sway bar mounts as I did not.
After the Strange recommended ring and pinion break-in, I realized I would hate the rod-ended suspension in a predominantly street driven car. The rod-ended components have made the rear end sound like it is ready to literally fall out. If this was predominantly a street car, I would not be running rod ends. At slow speed turns, the spool actually accentuates the noise of the rod-ended components. Since this is predominantly a drag car, I look forward to “no binding performance” of the rod-ended components.
dennsterTA
07-13-2012, 12:16 PM
Thanks for the pics Brian!
BrianSF-GA
07-16-2012, 07:37 AM
You bet ... let me know if you want to see particular photo or have a question.
GYTR-YAMI
08-01-2012, 11:07 PM
Well santa came early today, i got everything and its looking good already, i transfered almost everything over to the s60 and i just have a few hold ups from putting it in, but here are some pictures so far...
A few question tho...
Sway bar brackets that mount to the axle, do i have to buy these?
Do i need to use posi lube for the break in period?
should i just use the upper LCA hole for a stock application?
370ci_NBM_SS
08-02-2012, 09:53 AM
Looks good!!
I just used a bolt and locking nuts for the sway bar...(bolted it to the brackets welded on the axle tubes)
Not sure on the slip additive...i have a spool still breaking the gears....I'd call strange and see....
I would just make sure your lca's are pointed down towards the rear of the car
Mines is on the bottom hole
Carl at CRP
08-02-2012, 10:07 AM
If You have an aftermarket sway bar You will need that brand of mounting brackets to attach to the S60.
Do not use any additives or synthetic lube.
Yes.
Carl
BrianSF-GA
08-06-2012, 07:49 AM
Looking good so far ...
As far as your questions ....
Your S60 should have come with mounting hardware for an f-body which included brackets, end links and poly bushings to re-use your stock sway bar.
Use the lube that came with the S60 ... it is obviously what Strange Engineering recommends.
Whichever hole aligns your LCA's parrallel with the ground.
