Gen 5 Camaro Suspension Tech - Drive Axle Angle
View Full Version : Drive Axle Angle
benhardt57
07-10-2012, 04:23 PM
Referring to the 2010-present Camaro rear suspension, I am looking the for dimension (up or down) from the centerline of the wheels to the centerline of the differential where the drive axle attaches, while the car is resting on level ground. Or if it is easier, the angle of the drive axles from the differential to the wheels.
Thanks,
Ben
benhardt57
07-11-2012, 11:36 AM
Just so you know, I'm farting around with my own design using an LS engine and a Camaro rear suspension unit. The dimension I asked for is so I can properly set the location of the mounting brackets on my chassis. If anyone has access to this information I would greatly appreciate it!
Thanks,
Ben
