Generation III External Engine - Header issues
View Full Version : Header issues
Ddiehl02ls1
07-10-2012, 07:32 PM
So I just recently installed pace setter long tubes and a full exhaust and cancelled out the cats and the rear o2s but didn't have a place to hook back up the egr system is there a way to by pass it or do I have to drill a new place to put the egr tubes???
Sladester2
07-10-2012, 08:37 PM
you probably bought the "race" style headers. You can just delete the EGR.
Ddiehl02ls1
07-10-2012, 10:24 PM
How do you just delete it??? Just with a plate or plug the tubes??
Ddiehl02ls1
07-10-2012, 11:50 PM
So another question is why does it pop as in pop like backfire when ever I get on it. But all the spark plugs are good and everything else seems to be fine
PontiacFan
07-11-2012, 08:42 AM
Search !egr & !air threads on how to go about removing those systems.
You didn't mention what year the car was, so it may or may not have EGR.
2001-2002 did not, only AIR.
You may have cracked a plug or have a loose wire on the pop thing.
After removing those systems, you will also have to have the codes tuned out to eliminate any SES lights.
Ddiehl02ls1
07-11-2012, 11:57 AM
It's an 02. I checked all the spark plugs and made sure all the wires were on. I have 2 hoses that run around to the back of the intake that bolted onto the stock manifolds that are just pushing air out of them
MFJ
07-12-2012, 01:19 PM
Delete. Remove it all. Tune out the AIR system. Unless you have emissions testing.
