DeafDrifter
07-10-2012, 11:35 PM
Hi everyone, I have firebird trans am 1999 ls1 but short block are fucked up. ok i got good deal with CPR engine wanted trade mine firebird shell for ls1 5.3 aluminum plus cnc ported heads, that good deal? if yes, ok what is my plan build this engine for drift track.
part list:
katech rod bolts
melling oil pump high volume #689-10296
Comp Cams Hi-Tech Pushrods #249-7955-16
Comp Cams Pro Magnum Hydraulic Roller Lifters #249-875-16 or LS7 lifter?
SLP LS1/LS6 Double Roller Timing Chains #847-55000
Chevrolet Performance Head bolt #809-12498545
Patriot Performance LS Series Gold Valve Springs #723-8401
Chevrolet Performance Head Gasket #809-12498544
LS6 intake manifold
i have not decide on cams yet i need your help which better spec for drift?
Patriot Performance 225/229?
Comp Cams 228/230?
or what is you suggest?
i will stay with stock bottom block.
many thanks! look forward hear from you :) btw im deaf
part list:
katech rod bolts
LS6 intake manifold
Comp Cams 228/230?
