Broncojohnny
07-11-2012, 10:29 AM
My wife's car, a 2006 CTS-V has a starting problem that has me a little stumped. I wanted to run it by you guys though since my knowledge on these cars is very limited.
The situation:
-The car is 100% stock with 48K miles
-The car will start fine for a few days but then out of the blue will not do anything when you turn the key to engage the starter. Everything else works; Radio, windows, fan, power seats all fine, just no response from the starter
-Never has a check engine light
-The security light is not lit and does turn on when you put the key in the ignition but it goes out soon after
-The computer has never thrown a code based on my scanner
-If the car won't start and you push start it, the next time you try to start the car with the key, it works and continues to work again for a few days but then the problem reappears
-Already replaced the clutch position switch with a new AC Delco part
I am thinking that the ignition switch or the key is the culprit but from what I have read, the computer should throw a code for either of those items. The only other thing I can think of is that it could be the starter solenoid but I have never seen a solenoid that works absolutely flawless one second and not at all the next. Usually there is some laziness in the starter motor. Are the starters on these cars junk?
The situation:
