Generation IV External Engine - 6.2 engine weight
Jasperstang308
07-11-2012, 06:56 PM
I apologize if this has been asked before but I'm looking at doing a 6.2 swap into my foxbody coupe and was curious to what this engine weighs. I google searched ls1tech and couldn't find the answer.
I will be doing a carb swap since that will reflect the weight somewhat.
Thanks for the help
SSCamaro99_3
07-12-2012, 01:17 PM
Aluminum LS series motors tend to be about 430ish lbs.
Adam Connell
07-13-2012, 05:41 PM
^^^ what he said, I want to say the iron block weighs around 70lbs more.
1989GTA
07-13-2012, 06:36 PM
Just to add to the mix I have seen on a couple of sites that the LS3 motor weights #415. Take your pick.
HioSSilver
07-13-2012, 08:26 PM
w/o acceseries should be less than 400 for just the longblock.
Haggar
07-13-2012, 09:26 PM
I have put one on a game scale before, with PS pump and alt, no exhaust manifolds, it was ~425 lbs.
Jasperstang308
07-14-2012, 12:30 AM
so im looking in the 400 range. sounds pretty light for as many cubes as these engines can produce
82cetuner
07-14-2012, 01:31 AM
stroke one and you got more cubes than weight almost LOL
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
