headlights
headlights
how do I bypass my headlights when it becomes dark out? for my 2000 camaro when it becomes dusk outside or I drive under a bridge my lights flip on with no override capabilities. I want to be able to roll around during dusk with parking lights on. any help please
Copy & Paste Moderator
The Guz, that is more complicated that you really need to just disable auto-lights.
The quick/easy way it to short together the 2 wires going to the sensor on the dash next to the security light. 1 crimp connector across the 2 wires and you are done. Otherwise, if you want manual control, wire a switch between them instead.
BTW, this info is in the Lighting FAQ.
https://ls1tech.com/forums/appearanc...hting-faq.html
