General Maintenance & Repairs - what hose is this, and would it cause my a/c to run like crap?
jdoostil
07-12-2012, 11:33 AM
its idling not so well either. the car is in the shop now, so any help is appreciated!
99 TA LS1
Undertow74
07-12-2012, 11:49 AM
That is your PCV Valve hose, and with that being kinked like that, yes it will make your car idle like crap. Either rip the whole PCV system out and replace it with a LS6 valley cover, or just get a new hose for the PCV
LS1121
07-12-2012, 11:56 AM
pull that kinked hose off and replace it with a small piece of fuel line 3/8". I would also check out the rest of the PCV lines for rot. Probably find another hose set up ebay pretty cheap. LS6 valley cover is not necessary.....Period! Unless you just feel like spending money.
jdoostil
07-12-2012, 12:47 PM
Does that hose seperate, or is it just one long hose?
jdoostil
I'm thinking it seperates at the pvc valve?
jdoostil
07-12-2012, 02:18 PM
fixed! thanks!
sjsingle1
07-12-2012, 02:44 PM
if that happened to your little hose........think about the back of the hose behind the intake where you cant see it.........been there DONE that......LS6 valley cover FTW!!!!!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
