pajamasam
07-12-2012, 11:36 AM
Went to the dragstrip yesterday and it went decent since i didnt blow it up this time.
was running 12.0x all night with 1.8 60'
So i soften the crappy shocks and got a 1.7 60'
Best Run was 11.99 at 113 with a 1.73 60'
DA calculator said 2427ft
98 formula
ported 5.3 Heads milled also
236 242 .600 lift cam
ls6 intake
Stock Throttle Body
k&n FIPK
36lb injectors
Midwest converter ~3100 stall
Suspension:
Spohn
Adjustable LCAS
Adjustable tunnel mount torque arm
Adjustable panhard bar
Adjustable Drag Bar( no idea if i need to adjust or what)
LCA relocation brackets( im in the lowest hole right now)
WORN OUT Comp Eng Shocks
Where can i pick up some more 60' and mph. I feel like i should have more mph.
98 formula
ls6 intake
Stock Throttle Body
k&n FIPK
36lb injectors
Suspension:
Spohn
Adjustable LCAS
