Carbureted LSX forum - Car skipping @5,000RPM ??
View Full Version : Car skipping @5,000RPM ??
bluethunder364
07-12-2012, 03:10 PM
What are the symptoms of a bad cam sensor? and how do you test to check it. I assume a Ohm meter but what numbers am I looking to get if it's ok??
Thanks
ZONES89RS
07-12-2012, 03:50 PM
The MSD software if hooked up to a engine will detect if a sensor is bad.
bluethunder364
07-12-2012, 03:56 PM
Thats cool.......was unaware of that one! Thank you!! Problem now is still can't find the skip!
c4lhozwalte
07-12-2012, 07:58 PM
whats the rev limiter set at?will it pull past 5000rpms,or does it just rev to 5 and quit?
Gee101
07-12-2012, 10:49 PM
Did you buy the intake and box seperate? If it has the com port than you need to hook up the laptop and raise the rev limiter. My old box was set at 5200 and couldn't figure out why the pills didn't make a difference either till I looked at what the rev limiter was set at
dr.dub
07-13-2012, 10:47 AM
Is the rev limiter just adjusted on the graph? Or is there a separate setting for that?
Graybeards64
07-13-2012, 11:54 AM
The Rev Limit settings are found in the window labeled "data Editor FILE", not on the graph. That window is empty, until you open a file.
