LS4 Performance - New track times with TFS heads
View Full Version : New track times with TFS heads
DavidGXP
07-12-2012, 04:02 PM
Best run of the day was a 12.55@113.12mph with a 1.9ish 60ft. I also hit a 12.64 and a 12.67 with 1.9's I am having serious traction issues and ran a 13.0@113.98mph with a 2.3 60ft lol. My next mod will more tuning and sticky drag radials.
TFS heads have given me an average of 3 more mph. Last month I was trapping 109-110 and am now 112-113. The un-tuned heads have given me 25-30 more hp, with a lot more torque. With tuning I bet I will gain another 15whp. This would put me at 115mph.
Keep in mind that my previous 243 heads were pocked ported and slightly milled.
http://i48.photobucket.com/albums/f217/dapperdan1/2012-07-11_18-34-12_800.jpg 92* weather:mad:
BlackImpSS
07-12-2012, 05:25 PM
Nice times!!
You going to be strapped on the rollers when you get tuned? You should be pretty close to 400 whp if not a little over!
SeweRat
07-12-2012, 05:41 PM
Are you running the 5.3 or the LS1 Trick Flows? Part #.
Your response is appreciated.
94ss06gxp
07-12-2012, 05:55 PM
same mph as my camaro, nice times.
Sadden
07-12-2012, 08:58 PM
Makes me excited to get my cam build underway.
DavidGXP
07-12-2012, 09:03 PM
I am running the 4.8/5.3 205cc heads
DavidGXP
07-12-2012, 09:04 PM
Tfs-30510001-c00
vroom_vroom
07-13-2012, 07:07 PM
a god damn.
smokin06impala ss
07-13-2012, 10:53 PM
Damn.... That's fast . Congrats on your new times . Any vids ?
1CL3ANSUP3RSPORT
07-13-2012, 11:04 PM
That thing is a "BEAST" for FWD V-8
:lol:
SeweRat
07-14-2012, 05:12 PM
Thanks for the Info. Would there be any problem using the 215cc Ls1 Heads?
Part# TFS-3060T001-C01. Thanks for your help and expertise in this area.
I've been throwing together a build for awhile now and just couldn't decide
among stock 243 build-up, TFS 205cc, or 215cc heads.
supercatxr7
07-14-2012, 07:49 PM
Good job, keep going!
DavidGXP
07-14-2012, 07:51 PM
I would stick with the 205cc heads. They are designed for the small bore 4.8/5.3 LS engines. They will also bump your compression up to 10.6:1 with a stock .051" MLS head gasket.
The 2.04" valve in the 215cc head valve will kill performance due to valve shouding. The 2.00" is big enough. TFS moved the vlave angle to 13.5 degrees vs 15 (stock) to eleminate the shouding. This is why the head swap requires .100" longer pushrods.
SeweRat
07-16-2012, 05:51 PM
Thank you.
gxp-miller-gxp
07-17-2012, 03:04 PM
i have been debating on what heads to choose, i may get these, are you using the springs they came with or no? my biggest problem is choosing what cam ,lifters and rockers to use
The_Madcat
07-17-2012, 04:31 PM
Man, David, nice setup!
