General LSX Automobile Discussion - Motor pulled, what else while its out?
johnLs1camaro
07-12-2012, 06:25 PM
I was doing a head swap on my 98 camaro and noticed my pan gasket and rear main are leaking .. so i just decided to pull the Motor to fix those issues and clean the motor. What else should i do to it while its out?
JUSTINSWS6
07-12-2012, 06:27 PM
Clean and paibt the motor bay!!!
thompson
07-12-2012, 06:28 PM
Go ahead and replace the short block with the updated style block to eliminate the oiling issues of the 98. We can get you into a new short block for as little as $1519. This will keep you from having to go in there again and get you a motor with a warranty. Give us a shout at Thompson Motorsports 972-853-0518.
BLK95-Z
07-12-2012, 07:14 PM
While the motor is out you may as well go ahead and fab up a turbo :)
johnLs1camaro
07-12-2012, 07:25 PM
Good idea, that is something that needs done
Im actually in works of a turbo just waiting on a certain kit. Itll most likely be winter.
NC98Z
07-13-2012, 02:34 PM
New Rod bolts.
johnLs1camaro
07-13-2012, 02:40 PM
I worry about the issues people had from switching, i spin the motor at 6800 its been fine
NC98Z
07-13-2012, 03:18 PM
I believe the issue came in to play when they replaced them with ARP bolts that required resizing. Katech made some botlts that didn't. I hope your motor stays together for you spinning that high. Mine didn't. The Chevy Vette crate motor I bought to replace it didn't either. Thats how I wound up with a TSP forged 347.
johnLs1camaro
07-13-2012, 03:23 PM
Damn the luck, i did look into katech
mike171562
07-13-2012, 04:02 PM
motor mounts?
johnLs1camaro
07-13-2012, 06:02 PM
Already got polys.
hiram007
07-13-2012, 10:16 PM
motor mounts?
Thats exactly what I was thinkin but the OP took care of that already
garygnu
07-14-2012, 07:12 AM
if you are thinking about a turbo get a aftermarket K-member,it will give you more space for all the exhaust tubing.
sabersaw30
07-14-2012, 11:28 PM
Take some weight off the front end.
My6speedZ
07-14-2012, 11:31 PM
Do a wire tuck and paint and fill some holes. It is also a great time to do a line lock or ABS delete if it is anywhere on the to do list in the future. K-member is 100 times easier to do with the motor out.
