Carbureted LSX forum - Another Single Wire Corvette Alternator question
loyaltyisking
07-12-2012, 06:59 PM
I have a carbd LS6 with the corvette alternator. It is a 2000, with a 4 prong plug. I have the pigtail and every other part of the wiring ready minus the freaking alternator. I have searched high n low trying to find some info on my exact setup, or anything that I feel comfortable using as reference. HOW DO I WIRE THE PLUG? My alternator plug has an SFL labeled on it. Thats it. Its carbed and I dont mind running wires. Just dont wanna run the wrong wires. If some one can direct me or fill me in I would greatly appreciate it. Thanks!
loyaltyisking
07-12-2012, 07:09 PM
Oh I guess I should list a little more info-
I am running the Edelbrock/MSD box
The setup is in a 66 Chevelle, with a new american auto wire harness.
Tried to have powermaster build me a single wire corvette alternator......... Waaaaaay too much $$$
S10xGN
07-12-2012, 07:41 PM
I had originally planned on using the dash lamp but didn't realize the alternator won't work with an LED lamp (after I had just replaced all my dash lamps with LED's). So, on my '03 C-5 setup, I have terminal "F" on the alternator (terminal "B" on the plug) wired directly to a 12v "key on" source.
loyaltyisking
07-12-2012, 07:44 PM
Just that one wire? Everything I have seen has people using 2 or 3 wires. Sounds simple... What 12v source did you use? I see your setup.. NICE! What times you running in the 1/4?
S10xGN
07-12-2012, 07:47 PM
Yup, works for me. No 1/4 times, this is strictly a street car. No safety gear other than belts...
loyaltyisking
07-12-2012, 08:07 PM
Thanks I will try this sometime this weekend!
72ls1
07-13-2012, 08:21 AM
You should wire in a 470ohm resister in there.
hifi875
07-13-2012, 09:23 AM
what he said. 12v will not turn it on. its something like a 5v turn on.
S10xGN
07-13-2012, 08:34 PM
What you're saying is all fine and dandy if you are wiring through the "L" terminal. The "F" terminal on this alternator requires 12v.
loyaltyisking
07-18-2012, 02:54 PM
To fill everyone and any one who may be having issues with their alternator... What S10 said worked! I was nervous at first cuz I read you have to wire it differently, but nope. Works great. I checked battery voltage before start, at idle and after shutting motor off. Everything is as it should b. Simple, Thanks S10!
