gpr
07-13-2012, 12:29 PM
Got my 9" rearend installed. first thing i noticed is this thing whines and howls a lot, will that go away as the gears get broke in? I'm sure noping so.
Also there is a vibration which i assume is the driveshaft. I installed a new u-joint on the rearend side and left the stock one in the tranny. But it was good and turned free. I am reusing the stock drive shaft for now as i will be changing tranny hear shortly and didn't want to order another driveshaft when that happens as well.
My question is, what is causing the vibration? I have read it could be the pinion angle, but i'm not really sure how to check this. where do you measure the angle of the rear end at? I put my angle finder on the torque arm mount, but i don't think it is parrallel with the center line of the pumpkin, and there aren't really any flat surfaces to attach it to. (this is a quick performance rear end)
