Gears & Axles - Custom CV Axles
btlegacy
07-13-2012, 07:01 PM
We are putting a cts rear end in a miata to go along with an LM4 swap. Is it possible to shorten cv axles safely to use in the miata?
Pocket
07-13-2012, 08:21 PM
Yes, contact a local driveshaft shop about it
They press the yoke off, cut it to length and broach fresh splines on before pressing the CV yoke back on. You may want to inquire about changing the yoke to match the CTS diff as its unlikely the Miata CV's had the same spline count
btlegacy
07-13-2012, 11:38 PM
Awesome, we are actually wanting to use the cts axles since they are much beefier than the miata units. In a best case scenario we would like to take the axles and leave the diff side the same but shorten them on the hub side and press on the miata cv to be able to keep the stock hubs
btlegacy
07-30-2012, 01:16 PM
We haven't been able to find anyone in the area willing to tackle this.
Do you have any recommendation for shops?
Pocket
08-02-2012, 08:04 PM
Since you're in NC, contact olivers in winston salem
If that's a no-go check with import and corvette speed shops. Ask them where they get theirs. You can change directions and use half-shafts instead of solid axles, similar to how C4's did it. Those literally are half a DS, so any DS shop can build one to suit
btlegacy
08-11-2012, 11:10 PM
Thanks Pocket. We sent some stuff to Moser so we will see what they come up with
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
