Fueling & Injection - Pump not primming, but runs fine
View Full Version : Pump not primming, but runs fine
Z28MJ
07-14-2012, 03:47 AM
I noticed the other day that my car was real hard to start, so I checked into it and the fuel system is not priming right. When I turn the to on, it pressurizes it to 30psi but as soon as it hits 30psi you can hear something kick and it drops all pressure. Once I get it started it runs fine. What controls the priming? Thanks
Lonnies Performance
07-14-2012, 11:10 AM
It sounds like it is priming correctly but it is not holding pressure.
It only primes for approx 5 seconds.
If your pressure suddenly drops after the prime, you likely have a hose leaking in the tank, a bad regulator or an injector leaking.
Z28MJ
07-14-2012, 01:13 PM
ok I will look at those and go from there. thanks
Z28MJ
07-14-2012, 01:47 PM
It was the feed hose in the tank, you are my hero. Now for a question, when I first bought the car last year, the hose in the tank was cracked. I replaced it with rubber injector hose and it did not hold up, what can I use to replace it with?
Lonnies Performance
07-14-2012, 09:03 PM
The factory flex hose is what you need.
Rubber will fail....
Z28MJ
07-14-2012, 10:33 PM
yeah, I found out that rubber fails the hard way haha. Where do I get a factory flex hose? I never could find one except with buying a hole new bucket or a pump kit.
Hawaiian_Built
09-07-2012, 10:00 AM
I'm having this problem in my truck. Hopefully its just the line.
TAChief
09-07-2012, 10:57 AM
any fuel ine that meets SAE 30R10 will do. This is a very specific requirement.
http://www.gates.com/brochure.cfm?brochure=5091&location_id=541
http://www.oreillyauto.com/site/c/detail/GAT0/27093.oap?pt=N0887&ppt=C0222
Ollie8974
09-07-2012, 05:21 PM
2X what lonnie said.
Factory Flex hose.
THIS IS THE ONLY IN TANK HOSE TO USE.
http://www.racetronix.biz/items.asp?Cc=TUBE-03&iTpStatus=0&Tp=&Bc=
Hawaiian_Built
09-22-2012, 08:20 PM
I'm glad this thread was started as it gave me somethings to look at. I have to prime my truck about 3 times to get it to start. The first 2 times I can hear the pump but its faint. Around the 3rd time it sounds normal.
I pulled the fuel rail out to check for a leaky injector. didnt find one. I then pulled off the main fuel line to see if I was even getting fuel while priming. I let it prime once, checked the line and there was nothing. So I primed it 3 times and then I heard the pump get louder and then there was fuel coming from the line. Next thing to check is the intank hose. Does it sound like this hose is the problem? I also already swapped the fuel reg.
Ollie8974
09-23-2012, 07:03 AM
Factory Flex hose.
Yes, replace the in tank hose.
Ollie8974
Factory Flex hose.
As above.
