Miss Fire please help!!!
a while back i blew the oil pump in my car but before that it was fine. so i changed the oil pump pick up cam gear new gaskets etc. but now my car is mis firing and i cant figure out why. i changed the spark plugs myslef to e3's. my dad said it could be a injector or a wire but im to sure. can you guys please help!
See if u have a spark plug wire arcing. Open the hood when it gets dark and see if u have a light show. If u have a temp gun u can use it to narrow down what cylinder is not as hot as the others. Then u can change a plug, then a wire, then a compression check. And so on. Good Luck.
