LS4 Performance - Vector MS Heat Soak Reduction Kt
Dmac122383
07-14-2012, 05:26 PM
Hey everyone I'm wondering what everyones input is the Vector MS Heat Soak Reduction Kt for our LS4?
Is it worth it on our cars and will I see an improvement with the engine?
I'm also looking into getting a Power Aid TBS and wondering if its a benefit on our Ls4s also. I one on my 04 GTP Comp G and did notice it kept the throttle body cooler since it seperated it from the intake/super charger and also gave me some more throttle response.
I'll be buying both parts off a forum member at a discount so I wont be paying full retail.
Any info would help
Thanks,
Dave
LS1 Racing
07-14-2012, 11:42 PM
TBS is a serious waste of money on any car with port fuel injections (ours).
Some folks have claimed to feel a difference, but no one has ever proven the results on the dyno.
I can offer some firsthand experience: We just put a 78MM plate nitrous system on my Camaro. This is basically a throttle-body spacer with nitrous jets. When we re-dyno'd the car without the nitrous on, it made within 1 HP of a previous dyno pull.
Unless you're getting the TBS for $10 or something, IMHO, it's just not worth anything.
Aaron Arceneaux
07-15-2012, 04:20 AM
I had read iirc on gmls4 somewhere that tbs on stock LS4 manifold did make a difference because of that oil thing that protrudes in the opening of the manifold itself I will go look for that forum
http://ls1tech.com/forums/ls4-performance/1050073-airraid-throttle-body-spacer-verdict.html
06MonteSS
07-15-2012, 09:14 AM
I have the IAT relocate kit on my car... it works well and makes a difference.... TBS as mentioned above, is a waste....
Brian396
07-15-2012, 11:16 AM
MSD has an IAT sensor for $20 something. Requires a lil electrical work. (just have to cut and splice the wiring harness) if you really wanta do it on the cheap, I think you can get just the sensor for $5.
1CL3ANSUP3RSPORT
07-31-2012, 11:27 AM
Can we get a pic where you installed yours. Thanks Lew
The_Madcat
07-31-2012, 12:00 PM
First hand experience is hard to debate :)
I have always thought the TBS, not just our engines either, are poop.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
