diamond pistons? can these be used
on a stock crank 6.0 with forged rods?
http://www.cnc-motorsports.com/pisto...030-bore.html/
also any one using these pistons on a 370 cube
No. Stock crank is 3.622" stroke, those are for 4.0" stroke cranks, so you would either need longer rods than 6.125" or a 4.0" crank.
If you put that piston in with stock length rods and stock crank, it won't come up to the top of the bore and you will have super low compression.
