Dead at the key
Old 07-14-2012, 08:07 PM
czechnuts's Avatar
Default Dead at the key
I have a 94 Formula. I've had very little issues with thus car. So of course yesterday started great the first half. the after washing it. (Outside only) I went to leave and wouldn't turn over. everything else came on like it should. Figured ok starter. Well it did in fact go bad. I even jumped across the solinoid to see if I got a bunk one. So today I swapped the ignition switch. Still nothing. I checked wires, fuses, connections, etc. I even tried a different key. Can anyone help?!
Posted from LS1Tech.com App for Android
Old 07-20-2012, 08:09 PM
stinkynuts's Avatar
if it's manual i'd check the clutch pedal sensor (or whatever it's called). If auto check the brake sensor. They're under the dash (durr). I had the same issue with mine. Just cleaned the contacts and it was good to go
There's a LS1tech app now?? huh
Old 07-20-2012, 10:46 PM
MikeyZ's Avatar
check to see if your getting 12v on the purple wire at the starter
Old 07-20-2012, 10:49 PM
czechnuts's Avatar
It was the VATS. Thank though.
