Drag Racing Tech - Narrowed rear wheel width choices
View Full Version : Narrowed rear wheel width choices
TexasVortexx
07-15-2012, 12:56 AM
Wondering if any of you run an 11" width wheel on your narrowed rearends. I have 2.5" off each side and have been running 9.75" Bogarts but interested in bumping up to an 11". Any of you guys done this?
heymoej
07-15-2012, 01:11 AM
I am running 15x10 bogarts, tires are M/T ET Street Radial 325/50/15.....
my rear is narrowed 3" a side.had to do the BFH to get that to fit....
i dont know if an 11" rim would fit with out tubbing it.?.?
00bluews6
07-15-2012, 01:28 AM
you talking 15" or 17"
i have 15x10 and 17x11 for street no tubs
http://i259.photobucket.com/albums/hh317/00bluews6/2012-01-15203231.jpg
http://i259.photobucket.com/albums/hh317/00bluews6/2012-03-01182557.jpg
BADD SS
07-15-2012, 05:06 PM
An 11" rim will stick out a touch unless you have a really narrow tire on it. Thats not a crazy amount of narrowing, so most wheel options will be able to work. For instance, my rear is narrowed 4" per side, and my 15x10" rims have a 3.375" backspace, not many options off the shelf, but it's a lighter, stronger rear....
WheelsUp84z
07-15-2012, 05:57 PM
17x11.5 rears, no tubs. Thats with 5.25 BS
http://www.fquick.com/images/vehicles/full/35673365144.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=365144)
http://www.fquick.com/images/vehicles/full/35673365142.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=365142)
http://www.fquick.com/images/vehicles/full/35673365143.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=365143)
Fbodyjunkie06
07-15-2012, 07:52 PM
275/60/15 here on a 15x10" wheel 4.5" BS 3" narrowed on each side.
I have also had most of the rear inner fender removed, BFH modifications and the rear of my wheel openings have been very carefully trimmed and opened up more.
I can easily fit a 29.5x10.50W in there with a 12" rim.
Matter of fact my current 15x10" HoleShot Revolvers are a 3 piece modular wheel and I have the wider inner hoop that I can swap out for the ones that are on there now and make them 12" if I wanted to.
TurboStangJON
07-15-2012, 08:41 PM
15x11 Alumastar with a 3" backspace. The rearend is narrowed 5" per side so I had to do a lot of cutting on the wheelwell but it fits so far. However, that's with a 275 and I would have an issue running anything bigger. The tires were mocked up in the car first then we took a measurement based off of where they sat. Also, the control arms had to be relocated because the factory width would have ended up sitting on the housing end.
http://i48.tinypic.com/2vb5xkk.jpg
TexasVortexx
07-16-2012, 12:29 AM
I cut the bumpstops out and ran a 5.375" backspacing on the 15x9.75 wheel. With the 28/10.5/15 MT slick I have to use a 5/16 wheel spacer to gather more clearance on the inside front and top. The tire to rolled fender clearance was 1.50"+ wide with the spacer on, excessive. I'm wanting to buy another set of wheels but bump up to a 15x11 and want to identify the proper offset to avoid using the spacer to gain clearance. These wheels will have only MT 275/60/15 drag radials.
http://i27.photobucket.com/albums/c198/Texasvortex/IMG_4677.jpg
a98ws6
07-16-2012, 02:27 PM
Pics of those on the car?
WheelsUp84z
07-16-2012, 05:18 PM
gonna have to wait 2 weeks until I get back from deployment, But I'll snap some.... To give you a decent idea..(not my car)
TexasVortexx
07-16-2012, 07:35 PM
That looks real good... Im going the drag wheel route with black weld RT-S's
Fbodyjunkie06
07-17-2012, 12:30 AM
Also I will say I have the madman offset lca's.
Without them my tire would rub the control arm.
Firehawk441
07-17-2012, 03:44 PM
Good looking wheels. :thumb:
