Trans crossmember?
Trans crossmember?
Trying to figure out what crossmember most guys use when they do a LS/4l80e combo in a G body. I dont have the engine mounts just yet still trying to figure those out also but they may be a problem for the trans crossmember if i decide to move them back or forward for clearance! Is the big difference in the crossmembers the offset meaning they work with longer or shorter trans?
Bump! Seems like there are about only two crossmembers around Gforce and Icemans i hear the Gforce is very heavy but strong and the Icemans is light but flexible which may be a issue for big HP but i would like to save some weight!
