Drag Racing Results - Gained MPH but same exact ET
camz28arro
07-15-2012, 05:26 PM
Drove all the way to Englishtown, NJ yesterday with a couple buddies to see if I could finally break into the 11's. When we pulled into the racetrack parking lot we were greeted with a "test and tune cancelled" sign. Another hour later we arrived at Atco raceway where it started raining hard right as we pulled in. Luckily 2 hours later, the sun came back out and I was able to get some passes in.
My best previous pass with mods in sig but Mac Midlength catted headers and 6250rpm shift points was:
60' - 1.894
1/8 - 7.815 @92.68
1/4 - 12.122@113.35
Yesterday with ARH 1-7/8 catted headers and 6500 shift points (STILL HAVE 2.73s). Humidity was 91% and the temperature was 3 degrees higher than my previous best. Didn't launch as hard as I could have after seeing a mustang get sideways right in front of me.
60' - 1.967
1/8 - 7.916@92.23
1/4 - 12.122@116.19
Wish I could have gotten another 1.8 60' to finally get that 11 second slip.
moge11
07-15-2012, 05:47 PM
needs more converter and gear.. it will wake up with 4400 and a lil gear
camz28arro
07-16-2012, 05:05 PM
Anybody think going from 2.73's and ss3200 to 3.23's and ss3600 would gain me around 4 tenths and 2mph yet the converter will still feel the same around town?
camz28arro
07-16-2012, 08:00 PM
Also the DA was 900ft, does my 116.2mph seem a little low for 433rwhp/ss3200/2.73s?
No way. Too subtle of a change. 3.73's and an SS4000 would make a difference, and still be streetable. You can also try shifting a little higher as well to improve your et. GL.
got-a-ls1
07-16-2012, 11:28 PM
i dont think 2.73 to 3.23 is only a subtle change at all.. thats a decent change. Larger then going from 3.23 to 3.73. i loved my 3.23 with the stall converter. with ported ls6 heads, 226 234 eps cam, headers and 3800 converter i ran 7.37's 92-93 mph. 1.60 60's
at 92mph you can easily shave off 4 tenths IMO if your best is a 7.90 in the 1/8th
camz28arro
07-18-2012, 04:13 PM
Thanks, That's my reasoning behind the 3.23's too, most people gain nothing with 3.42s or 3.73s over 3.23s, plus all the other downsides with going lower gears. I see a lot of nice 60' times on here with the ss3600s too, not so much the baby stall in my car.
blk/slvr02ss
07-18-2012, 04:52 PM
I would go w/ a 3:42's and get those 60's down in the 1.6's and should be hitting mid 11's.
moge11
07-18-2012, 06:55 PM
3.42 and 4400 will get you a very nice gain
gs462
07-18-2012, 07:03 PM
At 116 MPH my GN would run 11.60s so Id say no.
gillbot
07-18-2012, 07:50 PM
I agree, i'd go 4000 and 3.42 gear at least. I went from 2.73 to 3.42 and holy hell the difference. Just wish I had a set of 3.73's to run.
moge11
07-18-2012, 08:04 PM
witha 4400 and 3.23/3.42 it will probably go 11.20's at 118+ in decent air
Camaro Z
07-22-2012, 06:12 PM
I'd say your MPH is there, what are you running for tires?
T6Rocket
07-24-2012, 04:09 PM
That would be a .9 second gain! :eek2:
Al
Roarin_8
07-24-2012, 04:13 PM
I think it is low for 433rwhp, I trapped 113 at Atco with 363rwhp, 70rwhp less than yours. You should be at 119-120. I also have 2.73 but still stock heads. My converter is a bit higher than yours, get the gear up to 3.42 or 3.73 and at least a 3600 converter. You're probably just getting into 3rd with the traps coming up a few feet.
What does your car weigh with you in it? I weighed over at raceway park and it came in at 3,505 back then.
Roarin_8
07-24-2012, 04:18 PM
Al
Converters are no joke, I gained a second off my ET with a drag radial and the converter. 13.2 to 12.2
moge11
07-24-2012, 05:34 PM
EXACTLY my point!... the power is there... its just cant leave hard... And when it DOES leave HARD, it will gain MPH and a LOT of ET...
