what should may air fuel ratio be
Old 07-15-2012, 06:49 PM
MIKEY'S 2002 TA's Avatar
Default what should may air fuel ratio be
hi, i have a 02 trans am ls1 with all the bolt ons. i just installed some new gauges and my air fuel ratio is at 14.60. i have a mail order tune and just wanted to make sure thats within specs. can someone that has experience let me know if its ok.
thanks,mike
Old 07-15-2012, 07:42 PM
MUSTANGBRKR02's Avatar
Is it a narrow band gauge or a wideband? Is this at idle/cruise or at WOT?
Old 07-15-2012, 08:00 PM
Default a/f ratio
at idle it starts around 13.00 and fluctuates when i give it gas. once it warms up it stays at 14.60 even if i give it gas. it stops fluctuating and stays at 14.60.
Old 07-15-2012, 08:38 PM
bayer-z28's Avatar
It depends on preference. I set mine to run at stoich once its warmed up (14.62 here.)
So there is startup enrichment, and once it's warmed up it leans out a little and runs at 14.62. Dialing my PE (POT) in now to 13. Should richen up a tad on WOT.
But yours sounds like it's dialed in the same.
Old 07-16-2012, 02:45 PM
SSpdDmon's Avatar
Good question - still no answer?
As for what the numbers should be (when using a wideband sensor/guage) on a bolt-ons car, 14.5-14.9 is target range for idle and part throttle. When the engine is under load and power enrichment kicks in, 12.7-13.0 is target range. Higher numbers are leaner and you don't want to go leaner than 13 at WOT.
Old 07-16-2012, 06:39 PM
redtail2426's Avatar
yup 14.6 normal driving,wot should be 12.7 to 13,like said no leaner than 13 at wot
Quick Reply: what should may air fuel ratio be
