procharger d1sc, j bracket, puller fans, griffen radiator
Category: Engine - Power Adders
Price: $2200
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): LA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
adding a set of puller fans, unknown brand. Which sucks cause these worked great on my car, ran them about yr, never one heat issue. I ran these on a LARGE Becool radiator with a custom shroud, these will not fit on the standard upright griffen most of the FI guys run. If anyone wants, I can get the part number off the radiator I used to run these. Dimensions on these are 12'' across measuring from flat side to flat side, and 12 & 7/8'ths measuring the other way. It appears the cap was dremmeled off so the fans would mount closer to the radiator. I bought it all on package and didnt know, or I probably would have never dismantled the shroud to get the fans off. I was told they were spal when I bought the setup but who knows. Would work good for a home made trans cooler like I built a while back. $40 a piece shipped SOLD
I also have a griffen radiator, the exact same one all the FI guys run upright. Its brand new, never installed. Part number is: GRI-1-25241-X. I am not uploading a pic of it right now but if you just desperately need one I can text you a pic. Bought it and changed my mind with what I wanna do, save on shipping from summit or jegs. $180 shipped. SOLD
Radiator sold. Hell I thought it would have sold by now. I spent forever looking for one when I bought mine. I spent waaaaay more than I should have when I bought it, so I am trying to recoup as much as I can. Thing is, this setup has an additional bracket that bolts to the oil pan for additional support. Thats not stock is it? I have never seen anything like it before, but I dont get out much either lol
If you separated it the procharger would go by it self. You could sell the pulley by itself, and the belts by itself. I'd want the j bracket and the stands and the idler pulleys and standoffs and bolts to bolt the bracket to the motor. I'd also buy a belt off of you, but would have to figure out a price.
Make offers. Willing to separate. This setup has an additional brace that bolts to the oil pan for extra support. If it separates, the 2 brackets will remain together, then the blower itself will go elsewhere.
I also will be selling a vortech mondo bypass, an ati super damper, and the 8 rib balancer pulley required to run 8 rib. Just havent had time to get this stuff off the car and take pics. It will be coming though
