Drag Racing Tech - lightweight column question
subhumanzz
07-16-2012, 08:38 PM
what are you guys using to start the car without the key? any pics?
Firehawk441
07-17-2012, 04:09 PM
I use a toggle switch with a 70 amp relay to turn the ignition on and a pushbutton with a relay to crank the engine.
ATwelveSec02Z28
07-18-2012, 07:58 AM
Since Im running an MSD ignition I have a toggle for the ignition, no relay as the MSD only needs a low amp signal to turn on/off.
and I have a momentary switch for the starter.
Crank the starter for a second or so, then hit the ignition and instant fire.
TurboStangJON
07-18-2012, 01:27 PM
I use a Spaghetti Menders system and the box is mounted overhead. It's easy to get to when strapped in.
http://i46.tinypic.com/24livqe.jpg
Outlaw666
07-18-2012, 01:47 PM
what are some of you using for a momentary switch and what is it rated at? Im looking for one that isnt that fugly push button with the rubber cover lol.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
