hellbents10
07-17-2012, 09:59 AM
2011 Camaro SS convertible
Engine: 6.2l, lightly ported cylinder heads, custom blower camshaft with matching valve springs &push-rods, displacement on demand and variable valve timing removal, LS7 lifters,4-corner cylinder head cooling, crank case evac system, Magnuson TVS2300 supercharger (11psi),Dynatech stainless steel long tube headers and high flow cats, stock cat back exhaust, 60lb/hr injectors, ZL1 fuel pump module, engine & transmission tuning
561rwhp through an unlocked converter.
Pedders Suspension- 1.5” lower
ZL1 appearance package.
Flaken 20” wheels- with stock Perrelli tires
This car runs and drives better then a stock SS. Even with 650hp this car retains a deadly silent smooth idle. exhaust noise at 70 mph is the same as when it was stock also, as it still has the stock cat back exhaust. This is a great reliable daily driver/sleeper!!! More power then a factory ZL1 with a convertible top!
Loaded with all factory options including heads up display!
Link to ebay for listing and pics. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190704236838&ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
