Gears & Axles - Rear end Whine/Wail under 70 mph
View Full Version : Rear end Whine/Wail under 70 mph
dano91
07-17-2012, 01:28 PM
Hi,
I have a 2000 Camaro SS A4 and it has an annoying wail/whine type sound from the rear below 70 mph. It is quieter, but noticable (and annoying) below 55 and just plain loud between 55 and 70. When I hit 70 mph and above, it is quiet. Any ideas? Rear end rebuild? Thanks.
sicksspeed
07-17-2012, 01:33 PM
Sounds like time to rebuild.if as loud as you say there is plenty of metal. All bearings need inspect/ replace.
dano91
07-17-2012, 01:46 PM
Thanks. Thats what i figured. Any idea on a range they charge to do this for these cars?
sicksspeed
07-18-2012, 04:46 AM
In the area of 8 hr. Labor plus all bearings than if real bad you have hard parts but usually not. Roughly 300 parts. Don't let any of those bearings from questionable source get in there. Or any from a country that starts with c .mechanic needs to do a tear down to check parts. I would want all bearings if it is real Loud just because the metal is every ware. That way you won't hear " I didn't touch that part"
