Priming Oil Pump?
Old 04-02-2004, 08:31 PM
HOTROD98Z's Avatar
Default Priming Oil Pump?
Hey i'm in the middle of doing my H/C swap and during the process of putting the new oil pump on i forget to pour some oil in to prime it. However i did turn the motor over by hand about 30 times trying to get the pickup tube to suck some oil into the pump. Do you guys think i will be alright or should i begin to tear this damn thing down again and pour some oil into it. Thanks
Old 04-02-2004, 08:35 PM
enginjoe's Avatar
Crank engine w/o the ignition coils connected. Look at the instructions at ls1howto.com for the cam swap. After cranking it a few times you can start it up, but watch that pressure like a hawk. It should come up pretty quick.
Old 04-03-2004, 03:01 AM
Mike94ZLT1's Avatar
Thats what I did, I left the plugs for the coil packs disconnected, and turned it over quite a bit. Haven't had any problems
Old 04-03-2004, 03:04 AM
HOTROD98Z's Avatar
Yeah i'm thinking as soon as its put back together, pull the fuel pump and ingniton relays and turn it over a few times, and this should prime enough oil into the pump, anyone else got any comments?
Old 04-03-2004, 03:28 AM
I can shift faster than you.
Jason99T/A's Avatar
The idea mentioned above will work great. Disconnect the coil packs and pull the fuel fuse and turn the motor over with the starter until you see your oil pressure starting to rise. Once that is complete, plug in the coil packs and put the fuel pump fuse back in. Then, fire it up!
Old 04-03-2004, 03:31 AM
HOTROD98Z's Avatar
Thanks man, my buddy thought that this method would work, but we just wanted to make sure before i put the timing cover back on.
Old 04-03-2004, 05:46 AM
DaddySS's Avatar
I always pull the ign fuse after an oil change and after three cranks at 5 seconds each the oil pressure starts to come up, so you will be just fine.
Old 04-03-2004, 01:49 PM
Hardtop00SS's Avatar
I would also pull the fuel pump fuse so while your cranking the engine over, your not dumping fuel into the cylinders, which causes wash down. good luck
Robbie
Old 04-03-2004, 08:09 PM
01_SuperSlow's Avatar
Old 04-03-2004, 08:45 PM
Blktie8's Avatar
Default Oil Pump
I just did a head and cam with the engine out and we primed the pump and
Believe me it is a while before the gage showed oil pressure
Its not like priming in the old days with a drill.
I believe my heart stopped a couple of beats and then viola 45 lbs with the new Katech pump.
Old 04-04-2004, 06:11 AM
smokin' joe 00 ss's Avatar
If you want a realy trick way to make sure you don't ever have a dry start this is what a friend just put on his new 383 stroker in his Checkmate boat.
http://www.masterlube.net/apps/classic.asp
