dbw pedal question
Old 07-17-2012, 03:23 PM
burbalanche's Avatar
Default dbw pedal question
i dont really know how to put this but now i have my motor all running i have a problem with the pedal.if i turn the key to just the on position everything works and i can press the pedal and hear my throttle opening and closeing(working) then when i go and fire it up i try give it a little gas and theres nothing at all no mattter wat i do. any help would be appreciated thanks
Old 07-17-2012, 06:05 PM
nobody?
Old 07-17-2012, 06:12 PM
Old Geezer's Avatar
How about explaining what parts you have...
Kinda difficult to t/s with zero info...
Old 07-17-2012, 06:15 PM
wat all info do i need to post? its a 04 6.0 from truck dbw new standalone harness computer tac and pedal also
Old 07-17-2012, 07:20 PM
bayer-z28's Avatar
Any CEL's? Have any been turned off or set to MIL on second error?
Old 07-18-2012, 08:13 AM
That im not sure of.i sent my computer tomy tuner also n he we nt through it quick with everything i have done to it so i was able to start n run it to check everything.
Old 07-18-2012, 03:35 PM
flame's Avatar
Make sure the TAC module stays powered during cranking
Old 07-19-2012, 11:35 AM
How can i test this?
Old 07-20-2012, 11:28 AM
flame's Avatar
Put a volt meter on the power wire at the TAC module while cranking the motor over make sure you have voltage
Old 08-27-2012, 08:52 PM
still trying to figure out this damn problem.i have voltage but cant seem to figure it out.anyone got ideas?
Old 08-28-2012, 07:46 AM
Old Geezer's Avatar
See post #5....
Old 08-28-2012, 08:28 AM
garys 68's Avatar
If it starts but no pedal, that can be a problem with the accelerator pedal position sensor or incorrect wiring between the TAC and pedal.
Confirm the your tac/pedal harness is correct. If that's ok, you might just try a new APP sensor.
Old 08-29-2012, 02:38 AM
zuffen's Avatar
I suspect I have asimillar problem with the DBW wiring.
Does anyone have the 2008 GTO dbw pinouts?
Old 08-29-2012, 04:21 PM
01WS6/tamu's Avatar
no such animal as a 08 gto
Old 08-30-2012, 09:39 PM
ok ill check that stuff out once..and the acc. pedal pos. sensor is that somthin u can just replace on it or would it be buying a new pedal? its an 04 thanks
Old 08-31-2012, 09:00 AM
Is there any way to teat if the sensor is bad before i just go buy one?
Old 08-31-2012, 09:48 AM
LS1Tech Sponsor
Slowhawk's Avatar
Probly a code missed putting it into limp mode.
Old 08-31-2012, 11:25 AM
flame's Avatar
Get it scanned for codes so that you know which direction to head
Old 08-31-2012, 03:41 PM
ok so i put a scanner on it quick and it read 4 codes.p0068 came twice and p0135 and po650.any one have any ideas or help would be much appreciated thanks. i have not had it tuned yet either still trying to get this figured out so i can get it done.
Old 09-01-2012, 04:07 PM
anyone?
Quick Reply: dbw pedal question
