General Maintenance & Repairs - 8 or 7 cylinders
Double J
07-17-2012, 03:23 PM
Can I get advice how I can tell if my engine is firing on 8 or 7 cylinders? Will I get a trouble code or engine light? I just changed my ignition wires and the rear passenger side wire recessed underneath the cowl was a bitch to plug in. Thanks on advance :)
eseibel67
07-17-2012, 09:25 PM
You will get an SES light and a code that ID's which cylinder is misfiring. If it's #8, the code will be P0308.
Double J
07-19-2012, 11:46 AM
Thank you, no ses lights or codes. So guess it's all good.
LilJayV10
07-19-2012, 11:57 AM
Why do you think you have a miss fire? Running rough? It still can be missing and not kick the SES light on. It has to miss so many times in so many cycles for the light to come on.
Do you hear any ticking, arching,snapping(I call it barking)from the spark plug wires? Also look at it at night. If you have one arching you can sometime seem a blue halo glowing around the spark plug boot.
DisasterFormula
07-19-2012, 12:13 PM
I think he was just paranoid about it.
LS1121
07-19-2012, 12:39 PM
If he has poly mounts it might feel like a miss but isn't.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
