bigti99a
07-17-2012, 03:53 PM
so i blew the rear yesterday. hole in the diff cover, after pulling it off looks like 2 bolts on the carier failed. the gears look good, pinion looks good.
its a 2000 z28 m6 with abs and trac control. anyone got a good carier for it or a good rear that is the same?? trying to do this on the cheap. car has just above stock power and is a DD with 172k+ on it. cant believe i got this long out of the rear.
i am in MD in the bel air area, but work in towson and would drive a little if need be. thanks fellas.
