Dyno Guesses & Bench Racing Forum - What should a 224 cam, Boltons, 3200 stall 100 shot TA on DR's run?
its turbo time
07-18-2012, 10:15 AM
Taking my car to the track Friday to run on and off the bottle.
Like the title says, car has full bolt ons, tune, 3200 circle d stall, 224 comp cam, and a 100 shot with 315 toyo tq drag radials.
What do you guys think it will do off and on bottle?
thunderstruck507
07-18-2012, 10:18 AM
I say low 12s/high 11s on motor and low 11s on spray
speedtigger
07-18-2012, 10:29 AM
Depends on if it will take that 100 shot off the line. If it does, high 10s if all is right.
its turbo time
07-18-2012, 11:08 AM
That's what I was thinking. I plan on spraying out of the hole.
It's the dry halo bar from nitrous outlet so it's a pretty soft hit
spicebird98
07-18-2012, 02:55 PM
what gears do you have?
its turbo time
07-18-2012, 04:54 PM
3.23's
JoshuaGrooms83
09-10-2012, 04:28 PM
and the results?
its turbo time
09-12-2012, 04:27 PM
Best i did on the bottle was 12.1 @ 115 1.9 60'
Swapped to an edge 3800 converter and did 12.1 @ 111 with a 1.6 60' off the bottle!
