need tire advice
Old 07-18-2012, 12:59 PM
ls1sickandtwisted's Avatar
Default need tire advice
Well yesterday i picked some GM stock Y2k rims for 200 so hopefully i got a good deal lol the fronts are 17x8.5 I have some tires in my garage 255/40/176 so im sure they will fit correct me if im wrong? the rear are 18x9.5 fyi not what i really wanted but for what i payed for cant be picky lol so for the rear how tall and wide can i go its for a Trans Am and its lowered 1.2in. I was thinking 285/45/18? Too big? Or whats the widest tallest tire i can run on the 18x9.5
Old 07-18-2012, 03:36 PM
blk97z28's Avatar
9.5 could be a 285, I have 17x9in and I run the NT05r Nittos, but they are a very fat 275 tire.
Old 07-18-2012, 08:27 PM
Yea me too i currently have the zr1 17x9 and i have the nittos on 275
Old 07-18-2012, 08:35 PM
cookba's Avatar
https://ls1tech.com/forums/wheels-ti...must-read.html
275/35 and 285/35 on the rear is ok. but also take into consideration the offset of the wheel as it might sit deeper in the wheel well or stick out closer to the fender. either scenario could cause damage. But TA's have better luck tucking tires.
Old 07-18-2012, 08:49 PM
It shows i can 285 but it wont tell me if i can do 40 or 45 worse comes to worse i do have some one inch spacers sitting on my garage
Old 07-18-2012, 09:57 PM
So guys whats the bigges tire i can run overall in height and width on a 17x9.5 on a trans am 1.2 drop and its a GM factory y2k rim?
Old 07-18-2012, 10:07 PM
cookba's Avatar
275/40/17 and 275/35 or 275/40 or 285/35 or 285/40 for the 18's
FYI. i ran 275/40/18 on all 4 corners with my Strano setup for 2 years before going to a new tire.
Old 07-18-2012, 10:13 PM
U think i can 285/45/18?
Old 07-19-2012, 10:19 PM
Old 07-20-2012, 09:47 PM
cookba's Avatar
thats a 28" tire. depending on the wheel offset and rear springs (stock you will have a better chance) you should be able to clear it with some BFH and rolling the fenders maybe have to throw out the bumpstop
Old 07-21-2012, 02:53 AM
So basically its a hassle so ur advice is to throw a 285/40/18 cus it will require minimal to none modifications?
