WHITE DEVIL
07-18-2012, 03:10 PM
Looking to sell or trade my 2000 NBM SS with 90500 miles
6speed
T-Top
Tan leather
power everything
A/c and heat work perfectly
Modifications are as listed:
Engine:
SLP air lid
FTRA
LS6 intake
CNCd 5.3 heads - dont have infor on them they were on the car when i bought it - verified CNC work and has dual springs
LS6 hot cam - Suppsedly
ARP head bolts
Long tube headers - true duals with bullets
HP tuners tuned
Made 370/370 on dyno jet
Power Adder: I installed this and it has 7 - 125HP shots through the motor
NOS 78mm Plate kit
#6 feed line
Andonized Blue 10LB bottle in back seat
N2O outlet purge kit
N2O outlet dedicated fuel system Fbody specific
Transmission:
Trans shifts smooth
Pro 5.0 shifter
Spec 3 Clutch - 500 miles
Tick Master cylinder - 500 miles
GM slave cylinder - 500 miles
Rearend and suspension:
Moser 12 bolt, 33 spline axles, HD posi, 3.73 gears, ABS and traction control all functional
UMI NON adj torque arm
BMR non adj LCA
Strange 10 way shocks on rear and coil overs on front with 300lb hypercoil springs
Extended Wheel studs in the front and rear
Hodgkis strut tower brace
Safety:
6 Point Wolfe mild steel roll bar bolt in - new
Stroud 5 point harness
Drag wheels:
Jegs Sport Mags - 15x3.5 with 26x7.5 MT sportsman tires - 15x8 with Hoosier 275/60 Drag Radials
Street wheels:
Fikse FM5 17x9.5 front with 5000mile nitto 555 and 17x11 rear with 315 555s
PM me your number or email me @ Jsmith137@slb.com if you have any questions
thanks
6speed
T-Top
Tan leather
power everything
Engine:
SLP air lid
FTRA
LS6 intake
ARP head bolts
HP tuners tuned
NOS 78mm Plate kit
#6 feed line
Transmission:
Trans shifts smooth
Pro 5.0 shifter
BMR non adj LCA
Safety:
Drag wheels:
Street wheels:
thanks
