Cadillac CTS-V - Removing power steering pulley
BudRacing
07-18-2012, 07:40 PM
I'm sitting here in the garage with the POS OEM tool from autozone and not having any luck. I can't keep the dowel straight and the clamps keep on sliding off of the groove. Does anyone have a trick to this? This supposedly simple task is NOT.
FuzzyLog1c
07-18-2012, 08:28 PM
I must be totally confused. Don't you just use a 15mm wrench and turn the bolt on the tensioner pulley clockwise to release tension on the belt?
1BADCTS
07-18-2012, 09:13 PM
You're using the puller with 2 metal halves and a ring that holds them together right? (best description I can think of). You don't use the 3 jaw kind.
Good luck!
Larimer
07-18-2012, 09:17 PM
I used the tool from Autozone with no problem. :confused: I took the radiator out and it popped the pulley off and it went back on without any issues either.
BudRacing
07-18-2012, 09:55 PM
Good luck!
That's the one. What a royal pain in the ass. I was actually able to get a wrench on the backside of the PS hose to get it off, but getting the new one on is proving to be very difficult with the pulley on.
The two metal halves don't get tight enough and slip off. I've tried taping them together and wrapping them over and over to make up for some of the space in the ring, but it's not working. I gave up using it.
Also, for those replacing their power steering pressure hose, removing the sway bar makes it possible. It's also a good time to replace those worn bushings. I wish I knew that beforehand.
BudRacing
07-18-2012, 10:17 PM
Tried again and finally got it. Turns out I had the metal halves backwards. Woops.
nasty_ss
07-19-2012, 01:44 AM
Any pics of the tool I the pulley? What is done with the hex screw in the center of the pulley?
BudRacing
07-19-2012, 08:50 AM
I'll snap some tonight. Didn't get it back together last night before calling it quits. I work slowww.
9t8z28
07-19-2012, 01:21 PM
Put a hose clamp around it. Thats what I had to do with the AutoZone puller.
soulja
07-19-2012, 01:32 PM
What are you working on, might I ask?
etcts-v
07-19-2012, 01:53 PM
Yeah same question, are you replacing just the pulley on the power steering pump?
BudRacing
07-19-2012, 02:20 PM
Neither, the pressure hose.
It's a real bitch getting the hose threaded onto the bottom of the pump with the pulley in the way.
lollygagger8
07-24-2012, 01:45 PM
So I need a tool to get the pulley off? I can't get the bracket bolts out since the pulley is in the way.....help!
http://i132.photobucket.com/albums/q16/n2havnfun2/Heads%20Cam%20Intake%20TB/PowerSteeringBracket1.jpg
BudRacing
07-24-2012, 04:16 PM
Yeah, autozone has the tool for a $42 deposit. Just remember the larger edged side of the grooved metal halves is what goes over the pulley side.
The bracket bolts are on there pretty f'in tight. Overly tight if you ask me.
Gabbiani
07-24-2012, 04:51 PM
I'll be pulling mine off tonight too. Must be something in the air.
