Will 65mm offset fit an 2002 camaro?
Old 07-18-2012, 11:11 PM
redssmaro's Avatar
Default Will 65mm offset fit an 2002 camaro?
Ive found some c6 z06 corvette rims. 18x9.5 front 56mm offset and 19x10mm 65mm offset. Will these fit my 2002 camaro ss or would they stick out? Help please. I dontvwant to miss out on them thanks
Old 07-19-2012, 12:03 PM
thmass6's Avatar
No, they won't. Both front and rear will be tucked under...a lot. You want offsets in the 40s.
Old 07-19-2012, 06:14 PM
VinR1's Avatar
Fronts will be fine but some run a small spacer
Rears will look better with a 1" spacer/adapter
Old 07-19-2012, 06:43 PM
redssmaro's Avatar
Ok. So all i need is spacers if im not wrong right.
Old 07-21-2012, 12:16 AM
99Bluz28's Avatar
The rear will work just fine, if you use a set of 3/4" -1" hub spacers which will make the 65mm offset into a 46mm(3/4" hub spacers) or a 40mm(1" hub spacers).
Quick Reply: Will 65mm offset fit an 2002 camaro?
