How many miles you still counting?
Old 07-19-2012, 04:28 AM
1_MEANZ28's Avatar
Default How many miles you still counting?
to all tx fbody owners ,how many miles does your ls1 have?
year
miles
mods
things replaced.
i have a 99 z28 cammed 102k miles
94 383 lt1 20k miles on build
99 ls1 z28 dd..236k miles
my dd has the high miles but is not underpowerd,has beanten low miles ls1 cars ..these ls1 motors are very good ..
Old 07-19-2012, 07:03 AM
cambirdracing's Avatar
Wifes 98 Z28 has 190k
Old 07-19-2012, 07:16 AM
thehulk2203's Avatar
1998 Camaro SS has 170k and is my daily driver
mods all the: bolt ons, suspension
things i had to replace: alternator, radiator only because when i was replacing the alternator i busted the radiator.
Old 07-19-2012, 07:19 AM
red281gt's Avatar
my 2000 z28 has 60k miles on body and 0 on the motor lol
Old 07-19-2012, 08:23 AM
SSHAWK's Avatar
2000 Ws6 Trans AM 44,002 miles.. all the mods listed in my sig.. Parts I had to replace power steering pump, battery,Headlight motor,Both door motors and brakes..
Old 07-19-2012, 09:50 AM
T3X_SS's Avatar
2001 SS 132K A4
LT's, MS3, and 3600 Vig stall
Old 07-19-2012, 03:24 PM
1_MEANZ28's Avatar
Nice to everyone, another thing that j need to replace on my dd is the stupid rack and pinion
Old 07-19-2012, 03:51 PM
NemeSS's Avatar
2000 camaro m6 130k
2000 trans am m6 228k
2000 gmc sierra rcsb 349k.
Most reliable vehicle i have ever owned.
Stock longblock 4.8, stock 60e. Stock tune, only have replaced wp,starter,alt. And fan clutch fan. no drips,leaks or noise. I forget if its on sometimes,gotta check gages to see if its on.
So quiet at idle. Rides smooth. Loves to rev. Still chirps gears wot. 60psi oil pressure.
23mpg on 87. Always keeps at 160• Even when towing, takes alot for it to reach 200•.
Ac is down right now. But i usually have windows down. I need to restore interior. Headliner is saggin.
Old 07-19-2012, 04:11 PM
BadxLS1's Avatar
2000 Z28 98K cammed, stalled, geared, bolt ons!
Had to replace power steering pump, and alternator due to the power steering leak.
Old 07-19-2012, 04:20 PM
z28_n_tx's Avatar
2001 z28 94k has become my dd as of 8 months ago
Replaced water pump. Drivers window motor ...
Old 07-19-2012, 04:23 PM
Ws6kid.'s Avatar
2002 TA. 98k miles. In my possession since i was 16. Engine has about 500+ miles. lol.
Old 07-19-2012, 04:29 PM
rcjoe's Avatar
73k.... h/c and all the other lil stuff added bout 10k miles ago
Old 07-19-2012, 05:36 PM
carlos sauceda's Avatar
2001 SS with 63k added cam bolt ons n other lil things about 2k miles ago
Old 07-19-2012, 06:44 PM
BIGDRAGON's Avatar
02 Camaro SS 6,400 original miles,full bolt ons,suspension,wheels and currently at Simple Quick Racing adding some Juice power.
Old 07-19-2012, 09:13 PM
JJsQwuik's Avatar
2002 Z28 A4
140,346 miles
Full bolt on's
Old 07-19-2012, 09:21 PM
Dave_the_SS's Avatar
2000 ss a4
117k stalled , cam, spray , and all the other boltons
Old 07-19-2012, 10:13 PM
dreww's Avatar
02 vette z51. W/ 81k miles owned for 1 yr
already fixed: driver front wheel hub, OAT sensor, wheel sensors
mods: bolt on, cam, wheels
2nasty's Avatar
7,100 all stock-CETA
76,500 stock for now DD-01 z28
Old 07-19-2012, 10:19 PM
Moderator
BizZzatch350's Avatar
1993 Trans Am - 73K - Heads & Cam LT1 w/ EFI 24X so LS2 Igntion and Ls1 PCM
2007 Corvette - 28K - LS6/M6 Bolt Ons
2008 GMC Sierra - 76K - Stock 5.3
Old 07-19-2012, 10:21 PM
MyFirstLS1's Avatar
2000 camaro m6
121k miles daily driven
Heads, cam, intake, suspension
Water pump, pinion seal, rear shocks, belt tensioner, resoldered bcm, brake master cylinder and passenger sise window motor. only things it has needed in my possession besides the obvious wearable items . Has gotten a lot more though
Quick Reply: How many miles you still counting?
