Gears & Axles - Is a 8.8???
01transampower
07-19-2012, 06:59 AM
My question is, is a 8.8 out of an F-150 longer then one out of a Ford Explorer? Over dimension wise or are they roughly the same? Because if it is and its usable I would rather have the axel tubes cute down then trying to have a sleeve made to mate the 10 bolt tubes to the 8.8 tubes.
Pocket
07-20-2012, 06:46 PM
Only the crown vic 8.8 is wide enough to fit under a 4th gen. All truck axles are too narrow to begin with
You dont need to make a sleeve either, you have to open up the truck housing or turn down the 10 bolt tubes for a slip fit. The sleeve method is an extra step so the tubes can be butted together vs slipped prior to welding
ss454327
07-25-2012, 08:59 AM
The 8.8 out of an F150 is 65" long.
01transampower
07-26-2012, 12:00 PM
Yea I already got my axel. I got it out of a 97' F-150 and it is wider then a 4th gen 10 bolt. All I will have to do is cut down the 8.8 tubes to make it have the factory length of a 10 bolt.
OldCobraGuy
08-06-2012, 12:31 PM
so you are saying you are going to use GM ends so you can use your axles and brakes? What about the bracket for the springs, panhard rod, etc?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
