Why is my idle at 1100 rpms???
My car sat for a almost 2 years and when I fired it up last weekend my idle is at 1100 rpms. It used to idle at ~750 before it sat.
I changed a few things while it sat....
Racetronix fuel pump & hotwire kit
Ebay Stepped headers & different exhaust
Switched from TR55s to TR6s
New Opti
But I don't think any of those would effect the idle
I checked the vacuum lines and everything looks good, both my headers are leaking at the head (new gaskets will go in this weekend) don't know if that will effect it either.
I had the motor out of the car, but didn't open the motor at all and it ran great before.
What do you guys think? I cleaned the air filter and MAF before they went back on the car, should I pull the TB off and clean that for starters?
New Opti
Run some Seafoam threw it too Settin is hard on things Clean the Tb that way you can be for sure that IAC & passages are Clean Definately get some new exh gaskets Stock ones work in a pinch
I'm not going to sea foam this motor. I'll pull stuff off and clean it, but no sea foam in this thing. My brother picked me up a set of Fel Pro gaskets that have always worked good for me in the past. The gaskets that came with the eBay headers are just plain worthless, should have went with my gut and put the Fel Pros on in the first place, but I got in a hurry so whatever.
9-Second Club
First, leaking header gaskets won't make it idle fast. Leaking intake gaskets would.
Second, if your seeing 1100 RPM on your factory tach, it's not idling at 1100. Those factory are always fast. Your idling more like 850 or 900. If it has much of a cam in it, that's probably where it belongs.
^^well before it sat my tach would indicate 900 rpms, but the data logger showed 700-800 rpms. I changed the header gaskets yesterday and it didn't change anything. I'm going to pull the TB off and clean it up and see if it helps, or I may just drive it and see if it goes back to normal.
I know the factory tach is off, but it idles too high right now, I can't hardly hear the bump of the cam
Thats why I told him to clean the **** outta the TB & Ed knows his **** IF you do everything & its still idling high its probably the rear of the intake leaking Get a good shop light & a mirror to look back there Seafoam will help clean that Carbon out Ive saved Seadoo & other PWC customers thousands of dollars When they let em set & dont properly store their ****!!! If you dont like that have a shop do an Injector Flush/Clean Itll do the same thing
Helpful answers or
Thanks
AFTER 90 DAYS THAT FUEL STARTS TO GUM UP & TURN GREEN!!! So settin 2yrs your gonna have some sticktion or dried out seals Ect.... Settin is hard on stuff! An Oring could be dried out & suckin air. Could be the coolant sensor on the water pump, Those get broke all the time Ive made thousands upon thousands of dollars from people lettin Seadoos & Boats set Most of em just over winter or longer Just tryin to help Take an injector out & see if its GREEN on top
Anyway...
I picked up a new coolant temp sensor today, gonna run the scanner and see what it says if I have time, but I may just change it and clean the TB Friday after the alignment is done.
9-Second Club
Why not look at it with a scan tool first? If it shows very cold, with the scan tool in hand, key on/engine off, move the wires & connector to see if the indicated temp changes. I see as many loose connectors as the sensors themselves. You can buy the sensor with a pigtail you can splice in. I would buy it that way if I were going to buy a sensor. Just put it away if not needed now. NAPA used to sell the pigtails. Not sure they still do.
Autozone sells the pigtail too. The connection is tight, but I will check that out to rule it out. I just don't have alot of time to work on the car since its 30 miles away and I have to have it in the alignment shop Friday morning. I'm going out Thursday morning before work to bleed the brakes and load it on the trailer, but I'll try to check it out with the scanner before I replace the sensor.
Thanks Ed
Thanks Ed
Something I thought that may be an issue is while the TB was off the car did you mess with the Throttle blade setup screw opening the TB more??
Once you Scan it you can also look at fuel trims possibly which may give you insight on a vac leak on a bank. Chances are if the IAC is showing 0 you either have the TB blade open too far or you have a vac leak.
I'll also check the voltage on the TPS. Like I said I just don't have a lot of time to get everything done by Friday morning.
I'm re-downloading the datamaster on my laptop and I need to find my cable, but I'll hook it up and see whats going on.
Thanks again guys
