Gears & Axles - Moser M9 vent?
6togo
07-19-2012, 07:22 PM
I have a M9 housing and it has a hole tapped for a vent and a barbed fitting came with it but i'm not crazy about the look of that and a rubber hose anyone come up with something that looked better?
XtraCajunCTS-V
07-19-2012, 09:33 PM
Its easy to find an NPT to AN adaptor and run a stainless steel braided line.
Shane
onfire
07-19-2012, 09:40 PM
Ran a 90 degree instead of the one supplied and ran a rubber hose up through the cross support over the diff,,,,,everyone will ask...where does that hose go?
6togo
07-19-2012, 10:40 PM
What goes on the other end if i were to go braided?
Pocket
07-20-2012, 06:43 PM
Nothing, its a vent
If the supplied barb clears, whats it matter what it looks like? Do people routinely inspect your rearend?
:secret2:
6togo
07-20-2012, 11:12 PM
This is a show and go build so i care what it looks like and there is no plain rubber hoses on this car! and i surely will not leave the end wide open even stock vents have some sort of breather tip inserted in the hose just looking for something decent looking.
onfire
07-21-2012, 11:13 AM
Make sure whatever you do, you keep an open vent or you will start pushing fluid past the wheel bearings.
6togo
07-21-2012, 03:07 PM
I need to find some sort of AN vent to go into the SS line instead of leaving a raw end open anyone seen something like that?
onfire
07-21-2012, 03:48 PM
Get crazy and put a K&N valve cover vent on the an line.
LS1-IROC
07-21-2012, 07:00 PM
I use sintered bronze filters. They look good and can be had with NPT or AN straight threads.
onfire
07-21-2012, 09:13 PM
Has to be bigger than the dime sized SI or it will not flow enough to keep the rear from pressurizing.
LS1-IROC
07-23-2012, 06:07 AM
Works fine for me....the filters can be had in different configurations that allow alot more surface area than what you are thinking.
6togo
07-23-2012, 07:36 AM
I found so threaded polished vents from Summit i think they will do the trick!
http://www.summitracing.com/parts/SUM-E730301/
onfire
07-23-2012, 12:54 PM
The one we tried was a tight mesh bronze. Wound up drilling a 1/8" hole in it to get enough airflow to keep the pressure down. I'm sure they make different styles with different void ratios that should work.
LiT1_up
07-31-2012, 05:18 PM
I used the stock one out of the 10 bolt.
