Dyno Guesses & Bench Racing Forum - what will it run? estimated hp?
willy9
07-19-2012, 08:18 PM
Ok guys, I have a 2002 ws6, 6 speed with, torquer v2 cam, longtubes, offroad y, spintech exhaust, plugs and wires, and a lid also running dragradials. My queation is what do you guys think it will run in the 1/4 with optimum conditions? And estimate hp?
Thanks
MyFirstLS1
07-19-2012, 08:29 PM
heads?
willy9
07-19-2012, 09:05 PM
241s with double 650 springs
MyFirstLS1
07-19-2012, 10:09 PM
400+ and high 11s with best conditions including shifts and 60' without shattering your ring gear with a good set of tires
willy9
07-19-2012, 10:19 PM
You think I can break into 11s? Sweet
ovaboost
07-19-2012, 10:29 PM
mid high 12's seen it many times unless you can rip that shifter low 12s
willy9
07-19-2012, 10:44 PM
Aww, I guess I need a good set of heads and a FAST to break into 11
ovaboost
07-19-2012, 10:47 PM
ls6 or fast will work so a good set of heads would get you into 11s with some good tuning and gearing
willy9
07-19-2012, 10:54 PM
Well I already have the ls6, what do you think of the stage one 243s?
streetknight2
07-26-2012, 09:11 PM
My car has those heads with a Torquer V3 cam and similar bolt ons to yours but I have a auto with stall and 9". Mine made 395HP/364TQ with the converter unlocked so a stick car with a 10 bolt ought to make 410-420 I would guess.
I have no 1/4 mile tracks close but my car only 60' foots mid 1.70's cause of a tight converter and runs 7.70's @ 93-94 in the 1/8
Good luck
mkvamso
08-06-2012, 08:46 AM
id spend some money on some suspension and a rear end. as it sits it could do low 12s or high elevens but i dont see it gettin there without a 10 bolt killing 60' and powershifting
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
