Newbie help w/ installing rockers
Old 04-03-2004, 01:52 AM
Tech's Avatar
Default Newbie help w/ installing rockers
I understand the process in adjusting the rockers/lifter preload on my 1.85 Comp rockers but I can't seem to get consistant results.
    My problem is that I'll adjust the intake valve rocker and the allen center will be very shallow while the exhaust rocker [allen center] will be very deep (or visa versa). There is no consistancy. Also, there is so little room between the cylinder head edge and the back of the rocker. I can barely get any pressure on the pushrod to spin it. After doing a single cylinder, I can barely feel the tips of my fingers.
    Zero lash seems very hard to determine because of the hard to reach pushrods. Are there any tricks? Should I go ahead and turn the locks 1 full turn since I can't spin the pushrods with any force? Anybody have any advice?
    Thanks in advance!
    Old 04-03-2004, 03:16 PM
    Tech's Avatar
    Surely someone has done this.
    Old 04-03-2004, 10:28 PM
    Tech's Avatar
    Am I missing something???
    Old 04-03-2004, 11:01 PM
    ram-it's Avatar
    Sorry no one has answered this yet for you. A friend of mine is going through the same thing. He got the proper advice on this over in our Northwest thread. Go over there and look at the Rocker Arm install problem thread and good luck.
    Old 04-03-2004, 11:03 PM
    ram-it's Avatar
    Aw hell, here's a cut an paste of it. Hope it helps.
    "Nate @ Nasty Perf called me. Nice! He gave me new instructions for torquing down the rockers. (get it to tdc, then tighten them down until the pushrod does not turn, and then 1 - 1 1/2 turns to 22 ft/lbs) But he agreed with checking for spark first....I'll aslo check for fuel (injectors clicking). But he said in all the cars they put these 1.8s on...and there have been several....nobody with a stock motor has needed shims. My car just wants to be different maybe. So I'll pick up some washers just in case, & dig into it again tomorrow."
    Old 04-04-2004, 12:11 AM
    Unaffliated Racing's Avatar
    those are completely different from the pro-mags..tech you need to give me a call, you know my work number, or drop me a line on my cell 901-461-2893
    later,
    brian
    Old 04-04-2004, 12:35 AM
    Tech's Avatar
    later,
    brian
    Thanks Brian. I'll give ya a ring tomorrow.
    Old 04-04-2004, 11:28 AM
    ram-it's Avatar
    I apologize if I pointed you in the wrong direction. I thought they tightened down the same way. Hey at least you now have the answer!!!
    Old 04-04-2004, 03:15 PM
    Tech's Avatar
    No worries ram-it.
    Brian, I tried to call you on your cell but it just rang. I'll PM you my number.
