qtp electronic cutout
Where would be a good place to weld in a qtp electronic exhaust cut out? Its a 94 Firebird, shorty headers but stock the rest of the way back. The car is also lowered 1"
Posted from LS1Tech.com App for Android
^^^Yeah, if you if look right under the rear passenger's side you'll see a spot up in there where it tucks in nicely, almost like GM knew we were going to need it for a cutout. Then you can run the wire right there through the rubber drain plug in the floor and up through the console.
thanks alot guys. have either of you heard the difference between 1 cutout vs 2? my cousin has 2 on an aftermarket y pipe and it sounds awesome. im hoping to have a similar sound with the one. also should i be worried about it scraping if i put it there?
