Daily driving 60 lbs injectors with a TSP tune?
Old 07-20-2012, 09:45 AM
needtransam's Avatar
Default Daily driving 60 lbs injectors with a TSP tune?
Ok so I was going to do the rear mount setup but cash is extremely tight and I don't think I can afford it right now, I guess im doing a racetronix fuel pump install that I had laying around already with a set of 60 lbs injectors for future turbo build, and was going to get an mail in order tune from TSP for this, question is am I going to loose a lot of MPG if I do this?
Old 07-20-2012, 10:14 AM
anyone?
Old 07-20-2012, 10:59 AM
1999Black_Z28's Avatar
If it's tuned properly you wont lose any MPG...if you do lose MPG than it's running too rich and not tuned properly
Old 07-20-2012, 04:02 PM
so even if i had 80 lbs injectors if they adjust the A/F ratio correctly I should stay the same just more power? would I noticed power with the tune and injectors by themselves?
Old 07-20-2012, 04:26 PM
JankesGTO's Avatar
uh thats a negative.. Just wait to install anything until you have everything lined up. Minimize down time and headaches in the long run.. Just my 2 cents.
Old 07-20-2012, 04:52 PM
WheelsUp84z's Avatar
no sense in getting a tune for injectors that wont help you any at this point, only to turn around and have to get re-tuned again when you put the turbo setup on.
Old 07-20-2012, 05:13 PM
makes sense you say just wait to get everything? its because I found a deal on some 80 lbs injectors?
Old 07-20-2012, 05:44 PM
unless you're tuning it yourself, you're going to have to paysome one to tune it for the 80# injectors, which will not give you an increase in power or drivability, and then when you do the turbo setup, you'll have to pay someone AGAIN to tune it. Buy the injectors if they are a good deal, and set them aside until you're done collecting all the parts you need, installing them now and paying for a tune is just a waste of time and money.
Old 07-20-2012, 08:40 PM
Captain Double Post
BOBS99SS's Avatar
Mail order tunes are fine for a bolt on car/but if your thinking a mo tune on a highly modified car is a good idea its not,especially after going boost,there are so many things that can come into play that a mo will do jack for, my buddy just had his turbo car tuned and he paid close to a grand i believe, kinda on the high side but they spent alot of time on it, just to give ya an idea for when ya finally get things together
Old 07-20-2012, 08:42 PM
Well i was going to get a mail in order than then tsp was going to take that in consideration when i get their dyno tune?
Quick Reply: Daily driving 60 lbs injectors with a TSP tune?
