Drag Racing Results - low trapping help???
lsx2000z28
07-20-2012, 08:32 PM
00 z28 stock cubs kaytech rod bolts, mti s1 cam, victor jr single plane, 90mm tb, moser 9'', 4.56 gears, m6, 26/11.50/17 ets (15 hot), stock heads, 12.12 @114 1.795 60's. going throught the traps at 7000+, shifting at 7200 2 step at 6300
Idk why it is trapping that low similar cars around me trap 120+
help please
thanks dustin
Doug G
07-21-2012, 07:18 AM
Have you tried lowering the shift RPM's to see what it likes ?
What are your trap rpm's ?
lsx2000z28
07-21-2012, 08:43 AM
No and around 7100rpm through the trap
moge11
07-21-2012, 12:35 PM
Well your already outta gear at the mph your at... try 6800rpm shifts and go from there. and put a 4.10 out back or get some 28" tall tires.
Doug G
07-21-2012, 01:52 PM
I would try lowering the shifts first....the Tq/Hp should pull those gears just fine.
moge11
07-21-2012, 02:06 PM
well when its nosing over at 7200 or so, and it needs 7600 or however much it needs to go 120+, Its OUT OF gear.... its not gonna run like he wants if its out of gear.
thompson
07-21-2012, 03:19 PM
Way too many RPM. There is no reason to turn that motor that high. Put it on the dyno, Ill bet it plays out 6150-6300 so all you are doing by turning it 7100 is slowing the car down and giving your best effort to spread parts.
lsx2000z28
07-22-2012, 11:26 AM
Ok I'm gonna try to shift it lower but my thought is it is my single plane. Flows to much for stock heads?
lsx2000z28
07-22-2012, 11:34 AM
And cam, specs are 244/244 612/612 112lsa
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
