How do I test a Idle Air motor?
Old 04-03-2004, 08:39 AM
BlackWS6LS1's Avatar
Default How do I test a Idle Air motor?
Car started idling like crap last night I jumped under the hood un plugged it and it didn't make any difference. I'm going out now to check for codes. Thanks in advance.
Tom
Old 04-03-2004, 09:34 AM
NoGo's Avatar
You can watch the IAC position on any scantool if you have one. It should fluctate slightly and open (increase) as you bop the throttle.
Old 04-03-2004, 10:48 AM
evil02z's Avatar
Also if you have a scan tool you should be able to adjust RPM which is the IAC.
