Fueling & Injection - in tank regulator,am i suppose to adjust it ?
devic
07-21-2012, 05:41 PM
so i just got a new in-tank regulator but now my fuel pressure is lower then before ?
i noticed tho that the little screw on the end is not screwed in as far as the original, do i need to adjust this and if so where to a get a torque bit with a little hole in the middle ?:huh:
Lonnies Performance
07-21-2012, 10:25 PM
That is called a tamper proof Torx. You can buy them at most good parts stores.
As for the regulator, the regulator is factory adjusted as an assembly. Once you mix & match parts from 2 different regulators (eg. putting the diaphragm from one into the housing of other) it may need readjusted.
