Dynamometer Results & Comparisons - 372 rwhp after ported fast 102 & long tubes -06 C6
gymratt
07-21-2012, 05:54 PM
http://i45.tinypic.com/288wgi9.jpg
I just had my 06 A6 coupe dynoed locally and I gained 14rwhp and 27rwtq with a ported fast 102. The car dynoed 342.37hp & 349.14tq with a vararam and 160 tstat.
I gained 20rwhp with obx long tubes and catted X with an ecs mail tune above the vararam & 160 tstat dyno pull. So grand total is 29.79 rwhp and 29.53 rwtq for long tubes, catted X and ported 102 fast. I still have the stock catback and stock UNPORTED throttle body. I've seen some gains as high as 60-70rwhp on this forum with long tubes, fast 102 and ported tb. It was mid 80's in the shop and 88% humidity for a DA of 1900 at the time. Weather or do I just have the opposite of a factory freak, a factory dud so to speak?
DietCoke
07-21-2012, 07:19 PM
LS2s dont put out stellar numbers. The tune is obviously off a bit too, I wouldn't be too worried. You gained a lot in the midrange, but the tune needs work for it to shine up top.
jmilz28
07-22-2012, 08:44 AM
DietCoke is right. I think you have several things working: weather, perhaps an average LS2, canned tune, generic headers. With Kooks or ARH, cooler weather, and a good tune, I think you'd see 15-20 more. Still solid numbers but the 60-70 you see was likely an LS3 cars running on a pig rich factory tune then done up properly.
reeperz28
07-22-2012, 08:53 AM
Adding a fast 102 on a stock cam usually doesnt show alot of gains. Cam doesnt take advantage of the air that the 102 can provide.
gymratt
07-22-2012, 02:41 PM
DietCoke is right. I think you have several things working: weather, perhaps an average LS2, canned tune, generic headers. With Kooks or ARH, cooler weather, and a good tune, I think you'd see 15-20 more. Still solid numbers but the 60-70 you see was likely an LS3 cars running on a pig rich factory tune then done up properly.Actually my header/vararam tune was an email tune, the ported fast and headers tune was done locally by a highly regarded tuner/speed shop on a dyno.
Kooks, LG and AR make great headers, but on multiple corvette forums the ls2 C6 dyno results between all of them and ebay headers have shown to be relatively equal. http://forums.corvetteforum.com/c6-corvette-general-discussion/2810338-obx-headers-with-cats.html
LS2's have seen gains in the 20's rwhp on bolt-on only cars with non-ported fast 102, stock cam.
I'm happy with the tune and how it drives. It idles and drives much smoother than the email tune. Looks like my car is an avg lS2 and weather didn't help. I will have to wait a few weeks for the track since it's been Africa hot with 90's most of this month with some 100's. Thanks for the feedback to everyone who responded.:cheers:
NVR_SPDS
07-22-2012, 03:41 PM
I dont think your numbers are terrible. Like was said, I dont think its an optimal setup (big intake/stock cam) but your also an auto, which will bring your numbers down some as well.
You could always throw a small-mid sized cam in it to take better advantage of the airflow from the new intake and see more gains.
redtan
07-22-2012, 05:30 PM
Your tune is hitting 12 flat AFR by the end of the run. Clearly that is nowhere near optimized. Who knows what kind of timing you are running with that thing.
With a real street/dyno tune you'll be hitting 390rwhp no sweat.
Slowhawk
07-22-2012, 07:49 PM
Looks good. A/F looks real good for a vararam setup since it leans out on the street.
I8UR4RD
07-22-2012, 09:48 PM
id love to see the gains with a decent cam. 230/232 600 lift 114 lsa. make that fast shine. seems like a safe tune!
jmilz28
07-22-2012, 10:58 PM
Good news on the background. The heat still sucks and the track will tell the tale once you get there. Any knock? How are your real measured MPGs?
gymratt
07-23-2012, 12:13 AM
thanks Redtan & Slowhawk.
NVR SPDS & I8UR4RD(great username): cam and stall are going to have to wait until spring. I spent more than I planned on custom car audio system last month because the factory "no highs, no lows gotta be BOSE" system gave up the ghost.
jmilz28- I'm not hearing any ping but I have to do some data-logging to check for KR. Been tied up the last few days unfortunately. MPG's definitely look better since the re-tune.
I've a C6, the Blose is the worst POS .......best turned off, what an ear bleeding painful, hateful thing to put in a car :aug2:
Did you change plugs by any chance to TR6?
gymratt
07-23-2012, 03:14 AM
Ctd- you got that right with the factory c6 audio. I put new TR6's & msd wires via the 99blancoss wire & plug special he runs on here and the other forum last year.
