Corvette Performance - C6 Z06 and ZR1 handling
View Full Version : C6 Z06 and ZR1 handling
Roarin_8
07-21-2012, 07:57 PM
I remember when the C6 Z06 first came out and people were complaining that the chassis was unresponsive, yet when the ZR1 came out, people loved the way it handled. What is were the changes that GM made and can those changes go to a Z06?
C5natie
07-22-2012, 03:09 AM
I'll paste it from wiki, less typing. Still, the C6Z06 handles better and sets faster laps in some places then the ZR1. Most reviews have called the Z more of a track car then the ZR1.
Ride control
The name of the ride control system is Magnetic Selective Ride Control (MSRC). MSRC is provided by Delphi Automotive Systems from technology invented by the GM Research Laboratories. The system uses two modes of control: Tour and Sport.
The system offers standing start launch modifications. When launching the ZR1 from a standing start, the shocks are completely softened on launch and stiffened on rebound. The softened shocks on launch aid the ZR1 by allowing weight to transfer to the rear, aiding traction. The ride control standing launch modifications are designed to minimize bounce.
Suspension
The ZR1 features a double-wishbone suspension (http://en.wikipedia.org/wiki/Double-wishbone_suspension) system and Magnetic Selective Ride Control—which adjusts shock-absorber damping in real time to either "Tour" or "Sport" mode.
The MSRC shocks are automatically adjusted based on driving conditions and vehicle dynamics (cornering, braking, etc) for optimal handling. The system is adjusted every millisecond to provide sharp handling during spirited driving, and a smooth ride while cruising.
The new high-end magnetic suspension system enables the ZR1 to deliver great handling and grip to achieve 1.10 g of average lateral acceleration.
C5natie
07-22-2012, 03:10 AM
Both cars share the same chasis but Im not sure if all the components can be swapped over.
Roarin_8
07-22-2012, 10:22 AM
So mainly, it's the shocks. The ZR1 shocks can be changed in real time with MSRC while the Z06 shocks don't adjust.
C5natie
07-22-2012, 01:59 PM
Plus the ZR1's electronic drivers aid which allows the power to be put down much more controllably. Even pro drivers have been faster with it on.
ThumperNC24
07-22-2012, 08:26 PM
the newer Z06s can be ordered with the ZR1 type suspension and I think that is considered the best handling track vette....
Roarin_8
07-23-2012, 09:29 AM
So you can get the suspension separately. So if someone wanted to get a Z06 USED, they can get the ZR1 suspension elsewhere then.
ThumperNC24
07-23-2012, 11:09 AM
not so sure about that. It wouldn't just be an easy swap since it is all computer control and you need the magnetic system, power, everything that goes with it. I don't think the system would be very easy to get aftermarket.
ysb02
07-24-2012, 08:01 AM
Only bad thing I've ever heard about the C6 is the vague steering compared to the C5. This is coming from people that tracked both.
jbs02somws6
07-27-2012, 08:27 PM
The difference in handling, or complaints regarding the z06, between the two cars (z06/zr1) when they respectively were released on the market was mainly due to tires. The Goodyear Supercar runflats released as OEM tires for the z06 are complete garbage even new when compared with ps2 or super sport michelins. Offering the Michelins from the factory in the last few years is the main reason the z06 is now running similar laps times next the zr1 on certain tracks. Yes the magnetic shocks make a little difference for all-out handling ability, but not nearly as much as the tires. I drove a 2011 z06 with the mag. ride control and it does make a BIG difference in ride comfort though, not like a new cts-v ride, but still michelins with the mag suspension will make a stock 06-10 z06 with goodyears feel like an ancient Roman chariot. (exaggerating to an extent):)
Roarin_8
07-29-2012, 11:15 AM
So if it's just the tires then, that would be an easy fix.
brewersprts
08-01-2012, 11:00 AM
Yes the tires make a huge difference. The goodyears are good tires, they just get hard and lose grip before they have very many miles on them at all. Also as with any runflat, Goodyear or Michelin ps2 the sidewalks are very stiff.
The zr1's and z06's you see running the blisteringly fat times are not wearing runflats, they're wearing the sport cup tires, which are basically dot racing slicks (I think the wear rating is like 60 or 80 or something crazy). That makes a huge difference.
But also, don't discount the mag ride or the ptm. Having launch control on either car helps anyone get it from 0-60. And the magnetic ride option is amazing.
ThumperNC24
08-01-2012, 04:10 PM
I think it was mainly the suspension...but the tires on the cars now (pilot sport cup ZP) are way way better than the tires that originally came on the cars. BTW - those can be had on both the ZR1 and the Z06.
The difference between the two cars was NOT just the tires.
The difference is most certainly the magnetic suspension (which has been available on the Z06 the last few years)
Roarin_8
08-02-2012, 09:10 AM
So in essence then, magnetic suspension plus tires.
6spdg37s
08-02-2012, 09:19 AM
I love the way my c6Z handles !
NW-99SS
08-02-2012, 02:26 PM
Z06 Z07 (Or Z06 carbon)= ZR1 suspension and tires. Any handling difference would be attributed to weight and placement of heavier components.
Already seen by a mag review that the Z06 with the handling package can be faster than a ZR1 around certain tracks.
Don't get me wrong, I want a ZR1, but the performance of a Z06 Z07 is astounding.
scramblerman
08-23-2012, 04:43 PM
I would get rid of the poopercar goodyears and get some better/stickier tires first. Then buy a set of pfadt or similar adjustable coilovers and call it a day. Last I had heard u cannot but the magnetic ride system on a c6z unless it was ordered from the factory like that.
ThumperNC24
08-23-2012, 10:24 PM
you certainly cannot do it easily or cheaply.
You are better off going aftermarket than trying to get that suspension...
